Hello,
I have tried many times to install the last version of CCleaner pro.
Each time I have the message attached.
I never had this before
Windows 10 famille
thanks for your help
Bernard
Hello,
Windows 10 famille
Bernard
I have the same problem
This warning is usually accompanied by ccleaner still running. Make sure ccleaner is fully exited including smart clean monitoring. Check task manager for ccleaner.exe or ccleaner64.exe. Kill those instances then manully delete the file c:\program files\ccleaner\ccleaner.exe (or the file listed in the error message). Finally click retry(recommencer in the screen shot).
hello Nergal
I do what you said and ......the install is OK
thanks a lot
Bernard
I have tried the solution, and when I try to delete CCleaner64.exe with administrators rights i get this message "file in use, cannot close"
Just make sure all CCleaner .EXE files are not running by looking in Task Manager, right-click any you see and select:
End Task
I have carried out all the steps you suggested, and I now have CCleaner.exe as well as CCleaner64.exe in the CCleaner Programme folder, see attachment. On checking it appears that theCCleaner software is now a 32bit programme, which seems wrong on a 64bit comptuer. Please advise. Thank you
You are showing both CCleaner.exe (32-bit) and CCleaner64.exe (64-bit) there. (You can't see the '.exe' part because of your settings).
That is normal, the installer puts both there.
Your desktop icon/shortcut will/may point to the 32-bit .exe but it's not a problem, when it starts it will recognise you have a 64-bit system and launch the 64-bit .exe instead.
(If you want to then you could change what the shortcut points to by right clicking on the desktop icon and selecting 'Properties').
Thank you, it is as you say
I deleted CCleaner Pro because it wouldn't install properly. Now I have tried CCtrialSetup and that won't install either. I have the latest version of Windows 10.
I've paid for Pro and I can't use it. What do I need to do? UGH
12 minutes ago, JimHockey said:<div class="ipsQuote_contents"> <p> I deleted CCleaner Pro because it wouldn't install properly. Now I have tried CCtrialSetup and that won't install either. I have the latest version of Windows 10. </p> <p> I've paid for Pro and I can't use it. What do I need to do? UGH </p> </div>
Do you have norton 360 for your antivirus?
