Fail to empty Recycle Bin
After running Ccleaner Recycle Bin shows 38 files at c. 26 Mbytes were deleted and Bin appears to be empty. However, running Ccleaner immediately afterwards gives the same indication for Recycle Bin (38 files at c. 26 Mbytes were deleted). Would be grateful for advice. (O.S.: Windows 8.1)
is this option checked? --> uncheck this.
Pic:
works it with w8.1-icon for recycle bin context?
Sounds like you have a corrupt recycle bin. The fix can be found here
http://forum.piriform.com/index.php?showtopic=42673
