Facebook problem
A privát kapcsolat bekapcsolása után nem enged bejelentkezni a facebook-fiókomba
14 minutes ago, Sajo666 said:
		<font>A privát kapcsolat bekapcsolása után nem enged bejelentkezni a facebook-fiókomba</font>
You will not be allowed to log in to my facebook account after you have turned on your private connection
Login to Facebook
Access denied
You are not authorized to access this page.
Password
Login
Forgot your password?
@Sajo666
Please stop double posting and using your email address as a thread title. Also never post personal details like that on a public forum. It is a privacy risk.
I have removed that info from your post and locked your other thread.
The "Private Connection" feature of CCleaner hides your IP address and makes it look like you are from a completely different location, which combined with the anti-fingerprinting feature, means that you can't be tracked across websites.
This can sometimes present a problem if,:
  • You are trying to connect to a printer on your home network - since you are now trying to connect from outside of home.
  • You are trying to to connect to a media service that is locked to your home country - if you are telling it that you are in different one.
  • Also, if you are trying to connect to online banking or to log into your social media account from what appears to be an unusual location, they may think that it is someone else trying to access your account, and require you to respond to some additional authentication in order to connect.
If you need to prove that you are where you actually are for any sites like these, the best solution is probably to switch off the Private Connection while you are using them, and switch it back on again when you want to go back to private mode when browsing other sites.
