Hello,
I need to recover all the files from my ext4 hd. I am using windows 7 and the latest version of Recuva but it can't access the hd.
Any help please?
Hello,
Any help please?
if this seems hard to do, i was thinking of formatting the hard drive to ntfs and then try to recover... would that work?
Last I checked recuva didn't do ext4 but that may have changed.
The latest version seems to do it:
http://www.piriform.com/news/release-announcements/2015/4/7/recuva-v152
Ok, I'm not sure why it didn't for you. Hmm, does windows see and assign a drive letter to the drive?
The last time I faffed about with ext4 it wasn't able to be mounted under Windows, so I had to use a piece of freeby software to act as an intermediary. Not very convenient, and I don't know if Recuva would be able to handle it, but better than formatting to NTFS (you would have to do a deep scan).
It would help if the release notes were a little more expansive.
windows is having a hard time reading the drive actually...
i have tried ext2fsd and extfs for windows and in both cases windows can't read the drive... do you remember which software you used?
also, my case is the following i lost all my files in the drive (ext4) if i format to ntfs (in case i cant get recuva to read the drive) would i be able to recover them?
thanks bro.
I think I used DiskInternals Linux Reader, which does not assign a drive letter. You could try Ext2Fsd, which does assign a drive letter (ext2fsd.com).
