Love your CCleaner and have used it for years. I recommend it to all my customers.
A feature I would like to see is the ability to export the addresses shown in the cookie tab. I use the hosts file to block ads on the website I view and would like to prevent the cookies from phoning home!
Change your ccleaner setting to save settings in "ini" format. This will make your cookies to keep list readable in a plain text format. However, you are better off just (on a monthly basis) updating your hosts file from MVPS or other source, they will be much better at figuring out what sites are advertising. Most cookies are not ad cookies.
