Ewido not showing up in my options.
I just installed CCleaner on another computer that has Ewido installed on it. Ewido is not shown in the options to clean. Under utilities in the applications tab I have Spybot and Ad-Aware listed but not Ewido. Why is this? Thank You.
someone with a similar problem HERE.
post 9 and 14 may be of some help!
-aaron
-aaron
Thanks but I already read that thread. It's dated June 22,2006 and there have been several updates to CCleaner since than. I thought the Ewido issue was fixed?
OK I have read that thread several more times. Does the winapp.ini need to be modified or should Ewido be showing up on it's own in the newest version of CCleaner? Also if it needs to be modified should I edit winapp.ini or do this in winapp2.ini? Thank You.
Do you have ewido installed to the default location? C:\program files\ewido?
Yes I do. I have the newest version of Ewido 4.0.0.172 and it is still on the trial version period.
This is the winapp.ini entry for Ewido in my copy of CCleaner version 1.32.345 slim version.
[Ewido Anti-Malware (Log)]
LangSecRef=3024
Detect=HKLM\Software\ewido
Default=True
FileKey1=%ProgramFiles%\Ewido\Security Suite|logfile.txt
FileKey2=%ProgramFiles%\Ewido Anti-Malware|logfile.txt
As you can see the 3rd file key mentioned in the thread is not present in my copy. Since I have the most recent version of CCleaner I wonder why it's missing? Should I add the entries listed in that thread and if so should I edit the winapp.ini or create a winapp2.ini. It was suggested to edit the winapp.ini directly and not winapp2.ini
Is this what it should look like
LangSecRef=3024
Detect=HKLM\Software\ewido anti-spyware
Default=True
FileKey3=%ProgramFiles%\ewido anti-spyware 4.0|logfile.txt
Can some one post what the winapp.ini entry for Ewido 4 looks like in the newest version of CCleaner?
LangSecRef=3024
Default=True
Thats what it looks like and ewido is detected by ccleaner on my computer.
LangSecRef=3024
Default=True
Do you have Ewido 4? Do you have the full or free version?
This link http://forum.ccleaner.com/index.php?showto...53&hl=ewido people were having issues with Ewido not showing up and the winapp.ini looked like the one you just posted. It had to be changed to work with Ewido 4.
How can I get Ewido 4 to show up?
Ah, now I get what your saying. I forgot all about the update, sorry about that.I guess the one that was showing in mine was the old version.(never even noticed :( )
Open up notepad and paste this in and save it as winapp2.ini(or just add it to that file if you have one already):
[Ewido Anti-Spyware (Log)]
LangSecRef=3024
Default=True
FileKey1=%ProgramFiles%\ewido anti-spyware 4.0|logfile.txt
I just tried it and it worked fine.
I'm sure ccleaner will have this default in the future but that should work for now.
Edit:
Or you could just replace the one in ccleaner's .ini file to make ewido appear only once. CCleaner includes all of the different versions just to cover which ever one various users might have.
Save in the CCleaner folder in a file named winapp2.ini if it already doesn't exist.
[Ewido Anti-Spyware 4.0 (Log)]LangSecRef=3024Detect=HKLM\Software\ewido anti-spywareDefault=TrueFileKey1=%ProgramFiles%\ewido anti-spyware 4.0|logfile.txt
Nevermind rridgely beat me to it.
Great that works thank you. The confusion for me was that I was under the impression CCleaner was updated to include Ewido as of this change log
v1.29.295
- Fixed IE 7.0 cookie cleaning.
- Updated Adobe Photoshop CS2 cleaning.
- Updated Ewido Anti-Malware cleaning.
- Updated Nero cleaning.
- Updated eTrust EZ Antivirus cleaning.
- Updated Hebrew Translation.
- Added Lithuanian Translation.
- Added Albanian Translation.
- Updated installer routines.
- Minor performance improvements.
and I have version v1.32.345 of CCleaner and use Ewido 4.
Everything is OK now. :D
