Evidence Eliminator
can a brain box help me with this please.
Dell inspiron 630m lap top XP
when going to my music folder. Selecting An album . then pressing Play all. WMP will open and play the songs
When i installed evidence eliminator. This one function stopped. after unistalling EE i found this function worked once more.
I tried it a few times. Same result Whats the work around.. to solve this
So my question is What file dose EE share with XP that stops me using the play all funtion in the music folder .
Please. The Reason I use Evidence Eliminator Is when you do the wipe the drive . I can go to sleep and let the computer put it self to sleep After. EE done its Job or just walk away.
I just wish CCcleaner had this function. Be perfect then
O_o wow I can tell you you're asking the wrong people, if this "Evidence Erasure" broke your puter you should talk to them.
while on principle this statement seems ok until you do that the computer goes to sleep and the HDD dies.
You may wish to rethink excessive drive wiping. Depending on the number of overwrites and the frequency of the wiping your HDD (and especially a SSD) will reduce the life and cause wear to come early to the drive
Agreed. Too much of that cleaning "business" isn't a good thing. And unless you're working with Top Secret classified data there isn't any need to be wiping a disk everyday. Or even eliminating "evidence". Please don't fall into that artificial, generated-by-someone-that-want's-to-sell-you-something, trap.
