Well if you want to give up I understand. Sometimes trying to fix computer problems is a huge headache. But if you don't mind hanging in there a bit longer I would really appreciate you helping me troubleshoot this problem. I did some searching and this seems to be a common problem so your assistance in solving the issue would be helpful to a lot of people.
I need some more information for more solutions.
If you could please click Start > Control Panel > Administrative Tools > Event Viewer
* Now click on 'Applications' in the Left Box > View > Filter > uncheck everything except for 'Warning', and 'Error > click 'Apply' then 'OK'.
* Now click on 'Action (at the top) > Export List > Save As 'Applications'.
* Now click on 'System' in the Left Box and follow the instructions above and name the file 'System'.
Once the files are saved please upload the files in your next post. Look at the bottom of your screen when replying...there is an upload option. Depending on the size of the files you may need to upload each file in a separate reply.
Now, here is what I have come up with so far on the topic...but I'm not sure if it will help you although I hope it will.
For Windows XP ONLY
NOTE: If you receive an error that reads something similar to ?Not all data was successfully
written to the registry. Some keys are open by the system or other processes" use Method 2.
Method 1:
1. Save REG File Association Fix to Desktop. Download Here
2. Extract the file to your desktop.
3. Go to Start > Run > type ?Regedit?
4. In the Registry Editor, go to File > Import, browse the regfile on the desktop that you just extracted, highlight, and hit 'Open'.
5. Reboot
6. Now double-click the CCleaner registry back-up, or right-click and select merge.
Method 2: Import the Regfile in SafeMode
? Turn on, or Reboot the computer.
? Start tapping the F8 key repeatedly.
? When the boot option screen appears select ?Safe Mode?.
? Press Enter. The computer then begins to start in Safe mode.
? Merge the regfile by double-clicking the file, or right-click and select merge.
? Reboot normally.
If either of these methods work for you please let us know.
Good Luck!
Per your request, here are the files I created.
