Error help me please!
Every time I open CCleaner I get this error.
Error
Exception EAccessViolation in modfle CCleaner.EXE at 0040A257.
Access violation at address 0040A257. Read of address A163E6B.
OK
Can anyone help me please! :unsure:
Are you using XP or vista?
Have you used CCleaner before?
Did you download from an authorised site such as the one here?
http://www.filehippo.com/download_ccleaner/
Which build did you download?
http://www.CCleaner.com/download/builds
I,m using XP
Yes, I have used CCleaner before
Yes, I downloaded the latest version of CCleaner at filehippo
Have you tried re-downloading it, as it may have been a bad or interrupted download.
Iv tried it several times it seems to be fine, but when I open it the error keeps pooping out until I close CCleaner.
It might be because you have another system cleaner that is blocking CCleaner such as Firewall, Norton360, McAfee, or virus infected cleaners such as FinallyFast, PC Confidential, or WinSpyware. The other reason may be because your computer is set to Max Protection where it won't allow you to install Anything!!! ;)
