What is registry booster? The issues cleaner in CCleaner?
no its some other program from (uniblue pc repair) but no repair. the point is the same error but opens
I asked what register booster is because sometimes finding the cause of a problem helps to solve the problem. You are missing a dll, possibly more than one. Not sure if regitry booster did it or what erased it. Anyway, I can try to post later about how to fix that. But I have to go to school now. later
thank you a lot. perhaps i did not explain good.
the problem started before "booster" just i started to search program that can repair one of them is that
booster.
and how it is related to ccleaner? those two programs popup the same error just the ccleaner doesnot work
but boster does.
and i want ccleaner
thank you again
I googled some of the Tech support forums and most came up with do a XP repair. However, someone had used this cure succesfully. Thought it may be worth a shot for you as you said a bad block was found.
[ chkdsk c:/r discovered that the file WINDOWS\system32\msvcp71.dll was corrupt]
For full syntax http://www.microsoft.com/resources/documen...k.mspx?mfr=true
ye i also googled it. the problem : i do not really understand that computers language. so the only what i can do
is to reinstall the win. i will do it later. the only program that is not working is ccleaner.
thank you
If msvcp71.dll is corrupt you should be able to download it from:
* http://www.dll-files.com/dllindex/dll-files.shtml?msvcp71
* http://www.driverskit.com/dll/msvcp71.dll/2371.html
* http://www.dlldump.com/download-dll-files_...8/download.html
You should probably check your installed version against those you download, so as to not go backwards in the version!
Note: Some applications also install that file, so it could've became corrupt from an installation that had a corrupt version.
HALELUYA !!!! THE CORRUPT FILE WAS MSVBVM60.DLL
CCLEANER BACK THANKS TO EVERYBODY
Glad you got it fixed
