just got the new one try it one time so now? not work to good said not did the free space. may be I go back.
You really shouldn't jeopardize your system integrity with a software that's just been taken over by an unknown entity, especially after reading some of his replies in that other forum I would avoid it. Maybe later on his coding may perhaps become trusted, etc. There's other freeware floating about that can wipe the freespace of HDD's.
Or just stick to an older version. I've stuck with version 5.7 after briefly trying 5.8 a few months after it came out and finding it buggy and any software that trashes my OS doesn't get a second chance.
Have used Eraser for a number of years and for the most part without problems. My last clean however indicated that Systems Restore or Volume Shadow "may have" not allowed Eraser to complete the job. Can't find anywhere on the Eraser website where I can get an answer to this and if in fact Systems Restore should be turned off prior to using Eraser. Any ideas??
Well, you could post on the Eraser forum. This is a nigh-on ten year old thread on another manufacturer's forum that, to be blunt, really has no relevance to your problem.
