Emisoft and Malwarebytes issue [FALSE POSITIVE]
Today my two anti-malware software -- Emsisoft Anti-Malware & Malwarebytes Premium -- went berserk over ccupdate5.66.7705.exe. Emsisoft immediately quarantined that CC Pro file. Then CC Pro became dysfunctional. I uninstalled and reinstalled CC Pro, but during installation, Emsisoft attempted to block the installation.
I KNOW CC Pro does not contain Malware. So, I request Piriform to look into the issue reported herein and attempt to resolve it. I have used BOTH Emsisoft and CC Pro in the same PCs since 2014 and never had a conflict betwixt them until now.
It's a False Positive detection of the newly released CCleaner version.
There is nothing for CCleaner to fix.
The few Antivirus Companys that have it wrong need to update their definitions - which is already happening, but taking a bit longer than normal because of Covid; see here:
38 minutes ago, prston said:
		Today my two anti-malware software -- Emsisoft Anti-Malware &amp; Malwarebytes Premium -- went berserk over ccupdate5.66.7705.exe.   Emsisoft immediately quarantined that CC Pro file.   Then CC Pro became dysfunctional.   I uninstalled and reinstalled CC Pro, but during installation, Emsisoft attempted to block the installation.
		<a class="ipsAttachLink ipsAttachLink_image" href="<fileStore.core_Attachment>/monthly_2020_04/399376836_CCMalware.jpg.422bae645e7be4e14f29f4bd364e2fe6.jpg" data-fileid="13426" data-fileext="jpg" rel=""><img alt="CC Malware.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="13426" data-ratio="80.11" width="372" src="<fileStore.core_Attachment>/monthly_2020_04/399376836_CCMalware.jpg.422bae645e7be4e14f29f4bd364e2fe6.jpg"></a>
I use Emsisoft and know that CCleaner is not usually flagged by them Make sure the detection in the Forensic Logs doesn't have a (B) after it. That means it was BitDefender who flagged it.
Open quarantine, highlight the CCleaner file, and go down to the bottom of the page and select 'False Detection'
nukecad -- Thanks for the link to the other posts reporting false positives on the new CC version. I know the Emsisoft founder Christian Mairoll. I will forward that link to him. It is BS that Emsisoft Anti-Malware should suddenly mess with CC.
hazlenut -- Thanks for the good advice. Regarding the prospect of a flag by BitDefender, I checked the logs. I didn't see the 'B'. See image attachment.
Question -- Since ccupdate5.66.7705.exe was located in a temp folder in the CC directory in Program Files, would there be any harm in just deleting it in Emsisoft's Quarantine? As a temp file, it is unneeded now, yes?
Again, thank you for your advice.
		<strong>hazlenut </strong>-- Thanks for the good advice.  Regarding the prospect of a flag by BitDefender, I checked the logs.  I didn't see the 'B'.  See image attachment.
		<strong>Question </strong>-- Since ccupdate5.66.7705.exe was located in a temp folder in the CC directory in Program Files, would there be any harm in just deleting it in Emsisoft's Quarantine?  As a temp file, it is unneeded now, yes?
		<a class="ipsAttachLink ipsAttachLink_image" href="<fileStore.core_Attachment>/monthly_2020_04/411464868_EmiLog4CC.jpg.cbfe4039a736c25518df3003771fa6b2.jpg" data-fileid="13428" data-fileext="jpg" rel=""><img alt="Emi Log 4 CC.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="13428" data-ratio="11.33" width="927" src="<fileStore.core_Attachment>/monthly_2020_04/411464868_EmiLog4CC.jpg.cbfe4039a736c25518df3003771fa6b2.jpg"></a>
I don't think it is flagged now?
Perhaps just report it here also
https://support.emsisoft.com/forum/58-false-positives/
