Email problem
Most every email in my INBOX the Subject line did not go with the messages and there was added data mix in .I don't know if Defaggler was the cause the problem.but it happen right after I ran Defaggler.
Any suggestion or comments about my email problem? I have never had this problem before. I would be very careful before I would run the defraggler again.
Defraggler uses standard Windows APIs to rearrange your file fragments (the same APIs used by Windows Defragment). So it looks very unlikey that the problems you have reported were caused by defragging.
MrRon
Sorry, you need to to formulate it again.
