Help
I did a resistry cleanup and I am now having problems sending e mails. I did create a backup. How do I reinstall it into my computer.
Lazer
Help
Lazer
Hi Laser, the .reg file is saved in my documents by default.
Right click on the file and select merge, then answer yes.
HelpI did a resistry cleanup and I am now having problems sending e mails. I did create a backup. How do I reinstall it into my computer.
Lazer
Thank you what can I delete in the regisry clean up and what should I leave alone?
Your welcome,
Augeas just gave another user some sound advise.
http://forum.piriform.com/index.php?s=&...st&p=134739
One thing I would add is to use Erunt to backup the registry.
http://www.larshederer.homepage.t-online.de/erunt/
Using Erunt in Vista: http://forum.piriform.com/index.php?s=&...st&p=125029
I personally have never had to restore the registry as a result of using CCleaner's Registry section. I find it to be non-aggressive compared to other cleaners.
Your welcome,
Jamin4u It's been a pleasure. Thanks for your help.
Lazer
