Edge Chromium skipped
I have used ccleaner for 20? years. This just started within the last 2 weeks. Can someone explain?
Lately edge gets stuck on exit, if you check under background processes on task manager you'll probably find it there under Microsoft edge kill the browser sub process and CCleaner should be able to clean
CCleaner used to close Edge.
