Edge browser not cleaning
Afternoon all,
I've just started on a new PC with windows 10. I've been using CC for at least the last 10 years without any major problems but I've just been experimenting cleaning the edge browser and find that with all options
ticked my recent history appears as I type. CC does appear to clean the history, as when I Ctrl+H the only history that shows is from the current browsing session.
But when I type a new search in the search bar all my past searches start to populate?? Am I missing something or is there a problem cleaning edge. Any help would be most appreciated, thanks...
Morning, I don't mean to sound pushy but does anyone have any explanation for my problem......................
there is a known problem with Edge that is currently a work in progress.
with Windows 10 and its constant build releases and Edge being the new kid on the block, I think Piriform is having a hard time pinning down exactly how to handle the constantly moving goal posts that is Edge.
Thanks for the reply, i supose it makes sense. I think I'll just have to be patient and see if it gets fixed in the next release. In the meantime I can manually clear my history from the settings if I feel a need to...
yes.
in Edge, top right corner, click the hambuger (those 3 horizontal lines), then click the 3rd icon from the left (History), than click Clear all history.
