LuLu's topic here Windows won't load... caused me to get out an old DVD with information on it about an Acer laptop. Thought that some of the info on it would be of use. My DVD drive now will not read it. It would read it before, and it wrote it.
Maybe someone might know of a quick fix, or some other way to read it. It has a ton of information on it, and I deleted the backup on the external USB drive. Ugh.
Pertinent information:
- The defunct DVD is a full size DVD -r
- - looks clean, no visible scratches, fingerprints, etc.
- - it is pretty old, has turned sort of yellow.
- The drive is an HP DVD writer 740b, which right now:
- - Will not recognize that the defunct DVD is in the drive.
- - Will read another DVD -r, a DVD +r, a CD -r, a mini DVD-r, and that is all I have tried.
- - Will boot and run a live CD, a live DVD -r, and a live mini DVD -r
- Recuva and others won't work, the drive doesn't recognize the DVD.
- Have tried one other CD drive, on a laptop, no go there either.
The only thing that has happened since it was "readable" is that I tried to manually eject a mini-DVD (not the defunct one) that was spinning and got a very disturbing rasping noise, but as said, everything else will still read, so I think the problem is with this DVD only.
Any ideas? Thanks.
