DVD Decrypter, and I've never had a failed burn, and you can configure DVD Shrink to use Decrypter, so all you have to do is change disk.
OK . . . so I'm not a video guy -- which I'm sure is obvious . Can you help me understand the basic functions of each of the following applications. At this point, I'm particularly interested in (DVD) movies:
DVDShrink
DVD Decrypter
DVDFab HD Decrypter
ImgBurn
Also, will a program like Ashampoo's Burning Studio burn movies/video?
I rip a movie with dvdfab, then shrink it with shrinkto5(found on filehippo) select main movie and slowest compression, then I burn the outputted video_ts folder with ashampoo.
Don't start out trying to back up one of your Disney movies either. I find that they are a bit tougher sometimes. Get the latest software and try out one of your older movies first to learn the basics!
Is there a freeware version of AnyDVD? By the way, is this a ripper or decrypter -- or both?
It is a decrypter and you can get a 30-day trial. It's probably the easiest method, but the freeware route will work just as well. DVDFab is updated frequently and can do your decrypting for you. Then use DVD Shrink or Shrink to 5.
The last time I used Ashampoo's Burning Studio it made an unusable DVD Video disc, that and the very first version that was offered for free had less issues than the newest one. Doesn't matter though because I've stopped using it.
What I like about ImgBurn is that it will warn if something is wrong, and in many cases can fix it with just one click of a button, whereas with many other burning apps they'll let you burn a non-functional DVD Video disc.
Do ImgBurn and DVD Decrypter essentially do the same thing?
No. ImgBurn doesn't decrypt movies whereas DVD Decrypter does.
If you're only burning pre-compiled .ISO image files either will work the same, although I prefer ImgBurn.
What I've preferred doing lately is using DVD Shrink to do all the decrypting and re-authoring in one go, and it has made DVD Decrypter obsolete for me lately, although I'll hang onto DVD Decrypter in case it's needed.
Re-authoring means cutting out the adverts, trailers for up and coming movies, long lists of credits, special bonus features etc.
In other words you tell the program just to copy the movie only.
Yup! Also to remove foreign languages, director's comments, etc., that consume disc space. In many instances the actual movie is within the disc capacity of a single layer 4.7 GB DVD, so in that case no compression has to be done for it to fit.
What I've found lately after really delving into DVD Shrink is that it's good for editing home DVD recordings of favourite TV shows/movies. You have to finalize your re-writtable DVD RW discs that by the way have to be recorded in Video mode, then use DVD Shrink to edit out all the commercials, and finally burn the re-authored version without the commercials to a DVD R.
