Duplikate Bereinigung Rückgängig machen
Ich habe vor ein paar Tagen den Duplikatefinder aktiviert und kann anscheinend seit diesem Zeitpunkt keine ACAD LT Files mehr ausdrucken. Kann man die Bereinigung rückgängig machen bzw. den PC auf einen alten Stand zurücksetzten ?
Danke für die raschen Antworten - wäre sehr dringend !
It sounds as if you have deleted a needed copy of a System or an Autocad file.
(In my opinion it is much too easy to delete needed files by mistake in CCleaner 7).
Did you delete the duplicates to the Recycle Bin?
Try restoring the files from the bin.
If you deleted altogether (or have emptied the bin) then I would next look at the printers entries in Windows Device Manager, and if necessary roll back or reinstall the printer driver from there.
With luck that will fix things, but if it doesn"t then:
It’s a few years since I last used Acad, but if I remember correctly it also has various configuration files for printing, and it may be one of those that is missing.
If there there is a “Repair” option in LT then try running that, otherwise you may need to reinstall Autocad LT.
