duplicate finder issue #2
I want to remove a bunch without having to click on each box one at a time ( But not all ) I tried shift or CTRL - no good
Unfortunately (or fortunately, depends on how you look at it) it is set up that way deliberately so that you have to at least half think about what is being selected for deletion.
It helps to avoid mass deleting the wrong files/copies.
