Drivers Could not be Updated
CCLEANER tells me all the time that I have drivers to update
but when I try to install receive the same error message
are you using the "PRO" version of ccleaner?
you can only update the drivers while using the "PRO" version of ccleaner.
you cannot update the drivers while using the free version of ccleaner.
Note that Driver Updater may issue a "could not update drivers" if:
  • You have an invalid Windows licence (you'd be getting a note from Microsoft every time you restart Windows, if that was the case)
  • Some updates may require others to finish before allowing others to proceed.
Can I check which version of Windows you are currently running (Windows 7 SP1, Windows 10 21H1, etc)?
And do things progress more smoothly after you restart Windows?
https://support.piriform.com/hc/en-us/articles/4402564268429-I-m-having-a-problem-with-Driver-Updater-What-are-my-options
DONT USE THE DRIVER UPDATE. I did, it damaged my PC. CCleaner refuses to fix it or pay Dell to fix it for me. This update will harm your PC and CCleaner will not help you.
