After using driver updater I have no sound and a AMD 'no graphics installed' error message.
I have tried to revert the updates but it is stuck on 'Reverting (blank) out of (blank) drivers' 'Do not disconnect or turn off your PC'
What should i do?
What should i do?
14 hours ago, R33Woody said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> After using driver updater I have no sound and a AMD 'no graphics installed' error message. </p> <p> I have tried to revert the updates but it is stuck on 'Reverting (blank) out of (blank) drivers' 'Do not disconnect or turn off your PC' </p> <p> </p> <p> What should i do? </p> </div>
Ideally give it some time to complete the revert. If you haven't restarted since starting the revert, definitely do this.
If you find this does not resolve the issue, you can follow the other suggested steps in our Driver Updater FAQ
