Hello, this is the second time CCleaner Driver Updater has removed my Sleep option from my power menu using Driver AMD Radeon HD 8650G.To get my Sleep option back both times, I had to revert the driver updates for AMD Radeon HD 8650G.
1st time was with version CCleaner v5.83.9050 (64 bit)
2nd time was with version CCleaner v5.84.9170 (64 bit)
I received your email and will provide you a screen shot of my display via my email response. I will also try to manually install the latest driver from the AMD website.
