Anyone know how/where I can download a printer driver for a HP Laser Jet 1020 printer? The disk it came with (3 years ago) isn't working. I switched from XP PRO to XP Home. After that, the printer stopped working. HP won't talk to me snce it's out of warranty (they want $60).
Other sites offering drivers seem like scams. Any help appreciated.
Thanks kroozer - yes, I had tried there, but I tried again. After 2 days of installing, uninstalling, downloading, etc, I still can't get the printer to work.
I actually had to switch my 1020 from one XP PC to another as it stopped working completly. Now (on the second computer) the Printer works fine but everytime I turn it on the driver says failed to load. . . which doesn't seem to effect the use of it whatsoever.
Thanks nodles - I clicked on the link and it turrned out to be an ad for driver update. About $30. The printer-spooler fix was about $35. If possible, I'm trying to avoid paying because I have no way of knowing whether these sites are legit.
I could not see any such adverts.
I saw information relevant to your problem on Nodle's link target,
and also on that page numerous links to other pages of site information,
plus an obvious advert link that offered me "customized drink coolers"
Either my browser gives me better protection from adverts,
or Google knows more than it should about your needs
Nodles asked "Is your Printer Spooler -service Started & Automatic?" and gave you a link to a page that told about the service.
I am NOT saying this will solve your problem, but it could be relevant to your problem,
and I certainly cannot see anywhere on the page that I could click and be offered and update for $30 or a fix for $35.
I have to suggest the possibility that your broser was subverted or perhaps a DNS poison attack.
Right in the middle of the screen that Nodles link gave I see
Print Spooler Service
Service NameSpoolerProcess Namespoolsv.exeDefault Settings XP Home : ManualXP Pro : Manual XP Pro w/SP2 : AutomaticMicrosoft Service DescriptionLoads files to memory for later printing.DependenciesRemote Procedure Call (RPC)Real World DescriptionWe used to call this the print que, but spooler works also.Is this service needed?
Possibly
Recommended Setting:
Automatic
Note Updated to reflect SP2 changes.
What this doesn't tell you is that if you have it disabled your printers won't work. Of course, if you don't have a printer (local or network) then kill this service.
Disabled ab-blocking etc. so I could check. Ads / areas for ads were pretty clear & ordinary for webpages like that, the site itself doesn't ask money from you. You've just misclicked an ad there or something.
Do you get any error message while installing drivers or while trying to print?
