I have two drives, C: has the O.S. WinXP and CCleaner. D: is a Western Digital 1TB Green drive. I was using the WD drive as extra storage but decided to install Win8 on it. In preparation for the install, I ran Drive Wiper. Thinking with an analog mind dealing with video tapes (FF through new tape to prepare it for recording), I ran the following:
Wipe - Entire Drive
Security - 3 passes
Drive - D
Seven hours later it was finished. I removed the C: drive and set D: as the master. Installing Win8 stops with the error no device driver. Subsequently, discover that the drive is not even seen by the computer. I return computer to original configuration. WinXP discovers the WD drive; thinking that this is the solution to the problem, I format the WD drive. Then I discover that the drive capacity is only 33mb.
I search Western Digital site for device drivers, none exist as they say Windows should recognize the drive (which it has done only at the much smaller size).
Researching this Forum has told me there should be a folder containing the data to be replaced onto the D: drive, but I have a feeling the Format has erased that folder.
I may have turned the 1TB into a brick, but any help would be appreciated.
I installed and used this software to restore my HD capacity. I had to give the WD drive it's own channel, run the software, turn off the computer and turn it back on. The computer stopped at the BIOS check and showed a bunch of letters and symbols. I turned off the computer and started it again. Now computer booted all the way. I then went to My Computer>Manage to recognize and format drive at its original size.
I like the Drive Wiper feature, though maybe it needs more description so analog bumblers like me don't create more work for ourselves.
I would like to add my congrats to Alans, and an appreciation of you taking the trouble to come back and update your topic with information which will undoubtedly help others.
