Drive Wiper doenst work
Hi all, just purchased Ccleaner pro as i want to securely wipe a hard drive. Unfortunately this function doesn't work... cant click on "wipe" as it stays grey.
Any help/suggestions?
And oh, it didn't work on the free version as well, so i thought it's a Pro function only
Please see here...
http://www.piriform.com/docs/ccleaner/using-ccleaner/wiping-free-disk-space
Method 2 (Manually wipe with Drive Wiper):
  1. Select Tools > Drive Wiper
  2. Choose the type of wipe you require:
    1. Free Space Only will leave your normal files intact
    2. Entire Drive will erase all of the files on the drive. WARNING, this means the whole of the partition will be erased. The drive will still be formatted, but all data will be erased. For safety reasons, this feature is disabled for the boot drive.
Got it working now, thx
