Drive Wiper and Eusing's Product
1. using the Drive Wiper to erase the entire contents of the A drive "(Entire Drive (All data will be erased)", above the progress bar, it says "Wipe Free Space" even though I am wiping the entire drive and all contents, not just the free space.
2. After I use your Registry Cleaner, there are still tons of stuff that Eusing's Reg Cleaner finds left over. Is there any way to configure your program so that I can use it without having to resort to another cleaner?
Thanks!
VR/Lost
CCleaner's registry cleaner is a safer one that most others, hence the reason it doesn't find as much. You really have to be careful using some registry cleaners since they can produce false detections of stuff that shouldn't be messed with.
Including CCleaner's (see my signature)
