Drive Mapping
I noticed once I installed CCleaner on one of my PC's my mapped network drives
changed the way the show in Windows Explorer
EXAMPLE :
Before CCleaner Install :
store on 'MES-File' (S:)
After CCleaner Install :
store on 'File Server (MES-File)' (S:)
why did it add "file server" to the drive name - - how can I change it back ???
I tried to uninstall CCleaner, but it did not change it back
Any suggestions on how I can get it back to the old way ????
Does this happen to anyone else ?? IF SO, what did you do ???
Found a work around ....
Put an entry in REGEDIT that will put the Drive Letters First - then the description.
(A:) Disk Drive
(C:) Hard Drive
(D:) CD Drive
(G:) Network Drive
(U:) USB Drive
everyone seems to like better ....
hey snowproblem and whom ever else what to know this
i have a better fix and it is called powertoys by ms just look at this site for the tweekui and all the other powertoys for windows
its at http://www.microsoft.com/windowsxp/downloa...ppowertoys.mspx
