Drive health warning on "Read Error Rate". What can be done about it?
There's a computer where I work that is showing an error stat on Defraggler.
It's much slower than it should be and I didn't even let it finish CHKDSK because it seemed like forever on verifying files.
Can something be done about it?
I think calling someone to repair the HDD would be more expensive than actually buying another HDD.
PS. The documentation is missing information on the "health" feature.
http://forum.pirifor...showtopic=35710
Which OS and Defraggler version?
You could try some other HDD test, too.
SeaTools
HDTune
CrystalDisk
How long did you let the Defraggler run?
Windows XP
Defraggler 2.09.391
I haven't "run" Defraggler, just after opening for the first time it already showed this information.
I could run an analysis 100% quickly.
Thanks. I was mainly pointing out the HDD test software there.
Oh, I forgot to say that the very own BIOS is showing an error message in the startup saying the HDD is faulty...
It must be cheaper to buy a new one than to plan a technical assist visit anyway right...
Then it probably is broken. Some manufacturers put HDD test in BIOS btw.
