[Double post] Question
Perhaps a silly question, but I was wanting to know if the winapp2.ini only cleans temps, logs, temporary internet files, left behind with all applications in its custom ini file...,
When I ran the ccleaner with the winapp2.ini under applications it had a lot of entries... Lots.. plus took forever to launch, which I read could be reduced by running the trimbat file.
But I was unsure what was cleaned by checking them, I didn't want it to delete my app, or remove any needed information for the application to run successfully. I also don't want to loose any specific profile settings, especially those entries with the * referenced by them.... I would give examples, but there is a lot to list...
Furthermore: I was wanting to know if these Microsoft Locations are included in the ccleaner winapp2.ini
and if they are all safe for cleanup -- like I said I don't want application runtime issues, or errors to happen... just cleanup of the junk....
Here are some Microsoft locations I found, can you kindly respond with which ones are included in latest winapp2, if its safe to clean, and which ones should not be touched.... Along with the orginal question about what all the winapp2.ini cleans... I don't need all the applications, I can see those, I just need to know if it cleans the temps, and etc.. or does it delete actual programs and or files that would cause it to not run right....Please and thank you...
#Inetpub
C:\inetpub\temp\IIS Temporary Compressed Files
C:\inetpub\temp\
#CCM
C:\WINDOWS\SysWOW64\CCM\Temp
C:\WINDOWS\SysWOW64\CCM\CIAgent\Temp
C:\WINDOWS\SysWOW64\CCM\CIAgent\Temp\CIDefnDownloads
C:\WINDOWS\SysWOW64\CCM\Inventory\Temp
C:\WINDOWS\SysWOW64\CCM\Inventory\Temp\FileColl
C:\WINDOWS\SysWOW64\CCM\Metering\Temp
C:\WINDOWS\SysWOW64\CCM\ServiceData\Temp
#Temp
C:\WINDOWS\Temp\
C:\Temp
#Web Extentions
C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\LOGS\
# Any User Profile
C:\Documents and Settings\%username%\Temp
C:\Documents and Settings\%username%\Local Settings\Temp
C:\Documents and Settings\%username%\Local Settings\Temporary Internet Files
C:\Users\%username%\AppData\Local\Temp
C:\Users\%username%\AppData\Local\Temporary Internet Files
C:\Users\%username%\AppData\Local\Microsoft\Windows\Temporary Internet Files
#NetworkService
C:\Documents and Settings\NetworkService\Temp
C:\Documents and Settings\NetworkService\Local Settings\Temp
C:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files
C:\Users\NetworkService\AppData\Local\Temp
C:\Users\NetworkService\AppData\Local\Temporary Internet Files
C:\Users\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files
#SystemProfile
C:\WINDOWS\system32\config\systemprofile\Local Settings\Temp
C:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files
C:\Windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Temporary Internet Files
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files
C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files
C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp
#Default
C:\Documents and Settings\Default\Temp
C:\Documents and Settings\Default\Local Settings\Temp
C:\Documents and Settings\Default\Local Settings\Temporary Internet Files
C:\Users\Default\AppData\Local\Temp
C:\Users\Default\AppData\Local\Temporary Internet Files
C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files
#DefaultAppPool
C:\Documents and Settings\DefaultAppPool\Temp
C:\Documents and Settings\DefaultAppPool\Local Settings\Temp
C:\Documents and Settings\DefaultAppPool\Local Settings\Temporary Internet Files
C:\Users\DefaultAppPool\AppData\Local\Temp
C:\Users\DefaultAppPool\AppData\Local\Temporary Internet Files
C:\Users\DefaultAppPool\AppData\Local\Microsoft\Windows\Temporary Internet Files
#Classic .NET
C:\Documents and Settings\Classic .NET AppPool\Temp
C:\Documents and Settings\Classic .NET AppPool\Local Settings\Temp
C:\Documents and Settings\Classic .NET AppPool\Local Settings\Temporary Internet Files
C:\Users\Classic .NET AppPool\AppData\Local\Temp
C:\Users\Classic .NET AppPool\AppData\Local\Temporary Internet Files
C:\Users\Classic .NET AppPool\AppData\Local\Microsoft\Windows\Temporary Internet Files
#PCHealth
C:\WINDOWS\PCHealth\HelpCtr\Temp
#RAC
C:\ProgramData\Microsoft\RAC\Temp
C:\Users\All Users\Microsoft\RAC\Temp
#Search
C:\ProgramData\Microsoft\Search\Data\Temp
C:\Users\All Users\Microsoft\Search\Data\Temp
# Assembly\NativeImages Net v2.0 \Temp
C:\Windows\assembly\NativeImages_v2.0.50727_32\Temp
C:\Windows\assembly\NativeImages_v2.0.50727_64\Temp
# Assembly\NativeImages Net v4.0 \Temp
C:\Windows\assembly\NativeImages_v4.0.30319_32\Temp
C:\Windows\assembly\NativeImages_v4.0.30319_64\Temp
#WinSXS
C:\Windows\winsxs\Temp
C:\Windows\winsxs\Temp\PendingDeletes
C:\Windows\winsxs\Temp\PendingRenames
#DriverStore
C:\Windows\System32\DriverStore\Temp
#System Center Operations Manager 2007
C:\Program Files\System Center Operations Manager 2007\Health Service State\Monitoring Host Temporary Files
# .Net Framework Net v2.0 \Temporary ASP.NET Files
C:\Windows\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files
# .Net Framework Net v4.0 \Temporary ASP.NET Files
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files
You have already asked this question in the Winapp2.ini file topic, please do not double post.
Topic closed!
