If such programs are configured to "run on startup" such as uTorrent you can either disable that during installation or in the settings after it's already installed. Of course if trying to disable things in CCleaner or MSConfig you may need to have administrator privileges.
Yes atleast ?Torrent is set to load with windows.There is no way to control this behaviour for the sidebar tho.
I am administrator.Full rights and UAC off.
What im saying is that prior to CCleaner 3.08.1475 the behaviour was that the entries became active again when i ran a program that had an active setting to start with windows.Now they do not become active.It is almost as if CCleaner is locking these down and the programs can't modify it so they create new identical entries.
Could it be related to this change in the latest version?
It could possibly be the changes in the Startup tool. If you want a previous version to test if it's because of changes they're always available at http://www.filehippo.com/download_ccleaner/
Yes this behaviour is not present on 3.07.1457 that i just tested.
Disabled the startup option in ?Torrent and will use CCleaner from now on to control it's startup.
both of the programs you mentioned are written so that if the startup is disabled it recreates it (apple's installers do something simular, if you've disabled "itunes helper" it will recreate it on the next update)
