Donations Question
Does MrG not collect donations anymore?
I can't find any donation links, only buy now. I have been away for quite some time so I don't know what the difference is between free and purchased, I just assumed that the purchased was for enterprise deployment but I will go investigate more now.
Nvm, I found the donation links. For some reason they are only listed in the FAQ section? Personally, I rather donate than buy because I use the slim and portable versions. Thanks!
And this is the link for anyone else.
http://www.piriform.com/ccleaner/faq/general/can-i-donate-to-piriform
You can still use the slim and portable, paid version also can update itself, no googles attached to paid either so it is relatively the same as slim
Yeah, I think that it automatically registered me for the paid version because it prompted a download link? Doesn't really matter, as long as MrG got some money... I was overdue.
