Hello Ive been using this program for a long time now with no problems how ever i installed it on my new computer running Vista home and the cleaner part works fine but when i click on the Issues option and try to clean stuff in the registry it finds things but never cleans them .... in other words when i hit clean all and rescan the same things are still there LOL is CCleaner not fully compatable with vista yet ?? thanks for any help o and it crashes all the time too
Try this. Right click on the CCleaner icon in your start menu and select "Run As Administrator" option. Run the program as you normally would. That should take care of it.
yep that did it thankyou
I am having the same issue (specifically windows media player does not have the previous video list cleared). Running as administrator did not help (though if it did, would I have to type in the password every time?). I'm also under Vista.
Please help!
Thanks.
Wrong section.
