Does leaving your PC on all the time cause problem
its best to leave the machine on most of the time as the most damage
is caused to a computer when it is switched on or off
internet cleaning tool
http://www.internetcleaningtool.net/
Install a Flux Capacitor with an oscilating reverberation reversible dynamic clutch decapitator with side to side dynamic harmonic distortion reductors... :lol:
It is much better to shutdown the computer because when you restart the computer it cleans the memory and it runs faster.
If you have the computer on all the time, then it consumes alot of electicity which is bad for the nature and gets you a higher power bill. It makes the CPU (Central Processing Unit - the processor) and the harddisk and other components hot/warm it also tears the fan and harddisks.
If you dont like power down your computer, because you want keep the computer at the state it is, then you can make the computer "hibernate", that way it saves everything it had in memory to the disk before it powers down. The next time you start the computer it will start faster and resume from the state it was, example all your applications will be open, and if you was playing music, then the music will resume at the same part/second of the song it was at.
If you anyways choose to have the computer always on, then be sure to use power saving functions and stand by functions to put the computer in "sleep mode" and power down the disk and power off the monitor/screen.
Also the more computer is on and connected to the internet, the more time it has to get infected by virus and such, be sure to run anti virus software and anti spyware software and firewall and to keep them up-to-date.
Quick tip:
If anyone does decide to leave their pc on all the time, turn the monitor off to save power and keep electricity bills down, even if only by a small amount.
I think thats a given :P .
Now that's pretty dang funny! Best I've read here so far. :lol:
Yea, incase your computer fries or something. Just travel back to the past when it was working again.
ive never had problems with my computer for leaving it on
plus ive got better fans though
so it doesnt heat up so fast, rebooting it helps everyonce in a while.
i did like the lighbulb theory also thats what happens when u turn your computer off and on after awhil
