Does this defragger optimize (compact) as well -- or is this just for defragging?
I used to think that one side effect of defraggin' was to optimize the performance of the hard disk, but as you ask this... I suspect that are they not the same anymore?... any light in this topic would be appreciated...
Greetings!!
Heres how I see it:
Defragging - grouping all of a files segments together so its no longer fragmented
Compacting (aka consolidating) - groups free space into one large chunk so newly created files arent fragmented
Optimizing - organizing the files based on access or modification date, or by file name.
Hi all,
i'm just taking a look on this soft.
Seemingly, when you select "Defrag Drive", first Defraggler defrags files then it performs a (very long time) compact, "consolidation" of empty spaces.
I think it's the first freeware defragmenter to do this. But i'm not sure.
Well, is this "consolidation" very important, interesting, i don't know ???
Nice day.
After all, it seams that Defraggler don't finish its job.
First time (all files defragmented, option Defrag Disk) :
Second :
Due to beta version ?
Even the Windows defragger does that.
Sorry, but i'm sure that is no. Windows defragger doesn't "consolidate" empty spaces.
Perhaps with Vista ? I don't know.
Sorry, but i'm sure that is no. Windows defragger doesn't "consolidate" empty spaces.Perhaps with Vista ? I don't know.
Actually, the Windows defrag utility compacts your hard-drive after defragmentation, which is essentially the same as free space consolidation.
