does c cleaner actually remove cookies
does c cleaner actually remove cookies from the hard drive as i am lead to believe they are still there
what does c cleaner actually do
Yes it does but bugs have been reported in some past versions ... and fixed. What version of CC are you running? What browser(s)?
??? What leads you to believe so?
i am running the latest version 205.i use internet explorer
iwas told by so called experts that cookies are only moved
Hothag, have a read of the guide
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
Hi Hothag.
If the Cookies are checked then they are deleted unless you want to retain certain cookies because you visit certain web sites regularly. I'm in about 50 different forums so I retain the Cookies from these forums so it saves remembering usernames and passwords. You would have to select these sites in the Options/Cookies dialog then these will be rertained.
If you use Recuva then after you have run CCleaner run Recuva and you will see all the files that have been deleted from your Cookies folder. ;)
