Under Options in Settings tab I have choosen "Secure File Deletion," specifically DOD 5220.22-M (3 passes). In my include window I added folders and files I wanted deleted. When I click on "Run Cleaner" nothing happens...I'm a little confused what am I doing wrong?
Hello, under Cleaner>Advanced>check the box for "Custom Files and Folders".
Just a word to the wise, be careful what you include!
The Following is a link to the CCleaner Guide.
http://www.ccleanerbeginnersguide.com/
Jamin4u
Jamin4u
Thank you for the info. I know what to do now.
woodycreek
