I run Windows 10 64 bit with the A/U and Ccleaner V 5.23.5808.When analized,some of the files I wish to delete launch a diologue box
with the message"Access is denied,you require permission from Trustedinstaller to make changes to this file".Any Idea what this means?
Nergal
October 22, 2016, 9:09pm
2
It means you're trying to delete a file you shouldn't, probably a system file.
Edit: trustedinstaller is a windows user, made by the system to perform certain tasks the files you are trying to remove are in a folder which has (or they themselves have) permissions your user isn't granted.
Thanks for the reply Nergal,it`s out of my comfort zone so I`ll leave well alone,although the files I wanted to delete
are old mp4 video files that I uploaded from a camera.
Nergal
October 23, 2016, 6:45pm
4
in that case
find the files
Follow this article
http://www.blogsdna.com/2159/how-to-take-ownership-grant-permissions-to-access-files-folder-in-windows-7.htm
Steps should be the same windows 7-10
