Sorry, misspelled Defraggler. Tried to edit it but was unable. (Mod edit - OK, done it for you)
I have a HP 64-bit computer.
Defraggler doesn't do well on it. My other computer is 32-bit and
Defraggler works fine. Unless you can tell me what I am doing wrong
I won't be able to use Defraggler on my 64-bit computer.
Thanks and sorry.
nodles
2
A bit more information, please? Does Defraggler crash or could you explain how it doesn't work?
Defraggler & OS version?
shankle
3
Thanks for responding Nodles.
I am running V2.11.560. I see that it is a 64-bit version.
Timings are way off.
Today it seemed to just hang and the % didn't change
The % of the the file fragmented didn't change either
Defraggler didn't crash.
Running windows 7 pro 64-bit with all the goodies.
ESET Smart Security - so no virus problem.
