As for the page file I have not touched it. It's at default or whatever it sets itself at when Windows is installed. This machine has 1.5 gig of ram.
I probably will go into system restore and really cut down the setting for how much space it can use.
1% is enough. Though, i got SR disabled completely.
As it says in site what hazelnut posted:
Setting the "Initial size" and "Maximum size" to the same values increases efficiency and performance since Windows does not have to manage re-sizing the swap file.
Disabling pagefile is even better, because then Windows don't have to read and write to hard disk all time, but keeping all the data in system memory. This requires that you got enough system ram.
It was at 6%. Not anymore.
Thumbrule is to set pagefile 1.5X of your system memory. So if you got 512Mb of memory, you set pagefile to 768.
That (1.5x memory) is only the minimum amount to use. From Microsoft:
The recommended minimum size is equivalent to 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB
As many places recommend setting min and max values the same I set min and max on mine to 3x RAM (I have 512Mb so set pagefile to 1536Mb)
Any ways today when I did the analyze with the Windows defrag the picture of the disk looked much different than usual. Check this out
That bunch of files on the far right is never there. I last defraged just over a month ago and they were not there when I did. So they have appeared since my problem started.
That happens on my system after windows has run the ProcessIdleTasks command (LINK), which it does every 3 days or so, always a small group of files moved out to the right of the disk display. To see if thats what is causing it you could defrag, check the disk analysis, then run the ProcessIdleTasks (Run>Rundll32.exe advapi32.dll,ProcessIdleTasks) command manually, then check the disk analysis again and see if you see the result you mentioned with files moved to right of disk (open task manager and make sure the defrag processes are finished to know if the command has finished, takes about 5 mins).
I found this a nuisance though as it undoes JKDefrags good work and am pleased to say I discovered Microsoft's TweakUI has an option to disable this - in the General section untick 'Optimise hard disk when idle'. Or you can edit the registry directly to disable it - LINK
You may want to have a look at your disk space usage with the app below.
Hi all
Been reading with great interest about hard drives free space shrinking, and used space mysteriously growing.
I decided to clean up the (System Restore Check Points) and recovered over 9GB of space back
That is interesting. The "optimize hard disk when idle" actually un optimizes ( is there such a word ) the disk. I guess Tweak UI is going in.
Hi allBeen reading with great interest about hard drives free space shrinking, and used space mysteriously growing.
Wow. What did you have System Restore set at for disk space to use?
Hi Anthony A
I just had a look, and it was set at 12% (22893 MB) so I reduced it back to 1% (2469 MB)
Initially Windows probably set it according to the size of my hard drive (200 GB)
That is interesting. The "optimize hard disk when idle" actually un optimizes ( is there such a word) the disk.
Indeed. I went an awful long time not knowing why I kept getting that group of files being moved to a big area of free space. Admittedly the ProcessIdleTasks command can speed up Windows startup if run occasionly but I'd rather choose when that is (I have the command in a batch file and run it once every couple of months now), not have Windows do it twice a week and shaking up my JKD optimised disk
I don't got that "EnableAutoLayout" value in registry. XP SP2.
Just install Tweak UI, then you wont have to manually edit the registry.
