disable icons and volue after i removed something on my ccleaner-start up
i used ccleaner for managing my startup in win7,but now when i turn on my laptop i lost some icon and my volume get mute,my function keys doesnt work!!! like i cant turn up or down my volume on my keyboard by Fn keys,or my brightness keys are disable!!
i tried to fix it on msconfig but after i turn off my laptop my setting change and again bein disable!!
pls help me
my laptop is macbook pro,win7 32bit,and my secondary key on trackpad doesnt work , i cant change setting on my boot camp control
You've disabled Bootcamp in the startup manager. Put that back on with CCleaner and you should be ready to go on the next boot.
Start "Bootcamp" manually on Windows via the start menu to test if that's the problem.
