Hi and thank you for the application and this forum.
I cannot uninstall Yahoo! Powered.
Can I use "Delete" from the tools screen? Is it the same thing?
Thank you for your feedback.
José
on HP i3 W10 Home - CCleaner Pro.
José
Yahoo Powered is not a 'normal' program I am afraid as you can see from here
It may be easier for you to go to one of the Malware Removal forums such as are mentioned in item 10 here
https://forum.piriform.com/index.php?showannouncement=15&f=4
