I'm running Defraggler 2.03.282
If you set it to move large files to end of drive, defraggler.exe works fine and the large files of the specified types get moved to the end.
If then the command line version (df.exe) runs from the scheduler or othewise... It moves all those files previously moved to the end back into the mix of the other files on the hard drive. This undo's all the work done by the GUI defraggler.exe! Hey Priform, please tweak df.exe so it can honor the settings set in the GUI version, or at least give me a command line option to do that.
Basically df.exe is ignoring move to end settings in the GUI. I know I could append lots of /large options to the command line... but that would be a pain.
Thanks for considering this issue.
