Destination drive detected as 11GB instead of actuall 11TB
Is there a way to either have the program ignore destination size? Is there a way to make the program detect the correct size?
I am somewhat stuck at this point.
Thanks,
Rick
I have purchased an 8TB USB drive to use as the destination, though using a mapped share from another device would have been easier and cheaper. Now it seems stuck on the first file and calculating time.
Still would like to know about wrong size on that mapped share.
Thanks,
Rick
