http://img85.imageshack.us/img85/3699/95689779dz0.png
should explain itself. i messed up the desktop icon by accidentally deleting the?desktop.ini?file.?any?ways?to?fix?it?
i'm on vista btw
i'm on vista btw
Might be some help below or maybe a system restore could help?
tried it but no luck. i need a desktop.ini file from another vista user. at least that's what i currently think.
oh and also, i've disabled system restore.
Just done a search for desktop.ini using Agent Ransack and it found 211 files all over the place.
should be in C:\Users\...\Desktop
Is there anyway you could use Recuva to get back the file you deleted?
I did have Vista on my laptop, but I reverted back to WinXP, otherwise I would've sent you the desktop.ini file.
Any help here John, it looks promising
http://www.askvg.com/how-to-fix-user-folde...-windows-vista/
Thanks for the link Hazel.Should come in handy for future reference here.
