Deleting Content.IE5 Is EXTREMELY Slow
It gives me three User Variables: MOZ_PLUGIN_PATH , TEMP , and TMP
It also gives a bunch of System Variables: CLASSPATH , ComSpec , FP_NO_HOST_CHECK , NUMBER_OF_PROCESSORS , OS , Path , PATHEXT , PROCESSOR_ARCHITECTURE , PROCESSOR_IDENTIFIER , PROCESSOR_LEVEL , PROCESSOR_REVISION , QTJAVA , TEMP , TMP , and windir
And, it gives values for each of them. What are they for??
I suggest you commence a reply to this, then :-
run CMD.EXE and issue the command
SET
That will display all system and user variables.
Right click in the centre of the display
Choose Select All - which results in white background
Hit the "Enter" key, which copies the display contents into your paste buffer, and restores black background.
Now return to the browser and continue your reply by holding down the Ctrl key as you strike the letter V
That will copy your information, all the names and also all the values for each.
Alan
Also open IE8 do tools- Internet options-general page.
Where it says browsing history press the settings button.
What location for temp files does it say?
If you click view files can you see anything?
