Deletes a lot less than it scans
Everytime I analyze, CCleaner deletes less than it analyzes. Although I know that the analyzation is just an approximation, sometimes the scan detects a lot more than it deletes. I just scanned my computer and it said that i could get rid of an approximate 19.1 MB. However, CCleaner only deleted 9 MB. Does this happen to anyone else?
Same thing happens to me.
Can you post or PM me a text file of both the analysis and the clean log?
Hello!
So far CCleaner has been an excellent tool.
But I have the same problem with v1.19.105.
It cleans a lot less, for example URL history is not cleaned at all. The previous version cleaned everything and very fast too.
Is it just me, or???
Cheers!!!
Hello!
Cheers!!!
Url History Is Cleaned For Me...I Am Also Using v1.19.105...Maybe Your Setting Is Wrong Or U Deactive The "History"...
Sorry MrG,
I can't seem to re-create the problem. It always used to happen. Its like it fixed itself. :huh:
Thanks for taking an interest in my little problem.
Latest news:
URL history is not cleaned when running CC with Explorer open.
URL history is cleaned when running CC with Explorer closed.
URL history was cleaned with Explorer open when running CC in the previous version.
So there is a small difference...
P.S. The history box is checked...
