Deleted Ableton projects
Hi there,
Like an idiots i deleted my Ableton projects around 15 of them and cleared the bin after that. There is at least 5, 6 projects that i really need back because i wanted to use it for an album. I downloaded Recuva on the Friday night and started a deep scan. It been scanning for more than 48h now. Stage 1 of 3, current progress : 25% 2070788 file(s) found and estimated time 6 days. I really need those files but at the same time i need to use my computer to work. I know my projects names in ".als" can i scan for a special type of file or i know where it was located maybe that would be quicker or is it better to go for the deep scan just too make sure? would it really take 6 days or more because it keep on rising?
My computer specs: windows 7, 64-bit, i5 cpu 650 @ 3.20ghz, 8 ram, nvidia geforce gtx 550 ti.
Thank you.
Double posted, thread closed to avoid confusion
