Delete
The Adblock Plus extension, which is not actually on the computer, is not removed. What to do? Other removal programs do not help.
Have you tried Revo uninstaller
you should find it in your browser's list of add-ons/extensions.
This extension is from Macrosoft Edge. But he's not there for a long time. There was just an invalid entry. Revo does not help.
With Microsoft Edge extensions you'll need to look throughout different places on your hard disk to find left-overs for an uninstalled addon/extension since it evidently isn't good at all removing left-overs - this I found out after uninstalling a different adblocker, most of it was still intact after I had uninstalled it.
Another option is perhaps reinstall that addon, then download Geek Uninstaller Free. In Geek Uninstaller Free click 'View > Windows Store Apps', then uninstall it from within Geek Uninstaller Free which should remove the left-overs. Now if that doesn't work you'll be left with trying to find all those left-overs manually in places like ProgramData, etc.
The problem is solved :) It turns out everything is so simple) I found the extension through the registry and deleted) But the uninstallers did not find anything) This is how)
Good news on sorting it out.
