Hi forum members,
I m planning to switch to Defraggler from my Diskeeper 2007. we all know that auto defrag is the main features of Diskeeper which means it always defrag your hard drive when ever you start your PC. Is this detrimental to hard disk drive? Davey post this:
in this link Will Diskeeper corrupt the hard disk because it always defrag it.My readings and use of each of these Defrag programs lead me to the following conclusions.I follow Donn Edwards advice for how often to Defrag.
If it takes less than 10 minutes, you are defragging too often.
If it takes more than an hour,you are not defragging often enough.
Defragmenting too often is just as detrimental as not defragmenting often enough.
Major updates,new program installs or old program uninstalls should be followed by use of CCleaner and then a defragmentation.
thanks in advance...
